Atex 94/9/EC annex II 1.2.7
Spurt ${formatDate(1381743420)} av exgrd | Siste svar ${formatDate(latestComment().postDate.timestamp)} av ${latestComment().author.name}
exgrd
I Atex guidelines 4. edition 2012 finner vi følgende utsagn:
Products for use in potentially explosive atmospheres are explicitly excluded from the scope of the Low Voltage Directive 2006/95/EC (LVD). All ""Low Voltage essential objectives"" have to be covered by the Directive 94/9/EC (see Annex II 1.2.7). The standards published in the Official Journal of the European Communities with reference to Directive 73/23/EEC may be listed in the EC declaration of conformity to fulfil the requirements 1.2.7 of Annex II of Directive 94/9/EC. Not excluded from the scope of the LVD are the safety, controlling and regulating devices mentioned in article 1(2) of the Directive 94/9/EC which are intended for use outside potentially explosive atmospheres but required for or contributing to the safe functioning of equipment and protective systems. In such cases both Directives shall be applied.
Mulig jeg er helt på bærtur men såvidt jeg kan forstå vil utstyrsdirektivet dekke LVD med unntak av for tilhørende utstyr Exi.
Stemmer dette?
Hadde vært så mye enklere om direktivene var skrevet på engelsk.
