If I have one Eex-ia Pressure sensor, two EEX-ia modules connected in series in hazardous area and a barrier in safe area. How will I make an IS loop calculation?
A. Shall I create 3 loop calculations checking IS loop for 1.Pressure sensor and module 1, 2. module-1 and module-2 and finally module-3 and barrier
OR
B. Shall I add the values for all the EEx-ia devices in hazardous zone and compare it with the barrier.If this is the way, can I simply add the values or i need to use old school theory. (eg: Li =Li1+Li2+....Lin & 1/Ci=1/Ci1+1/ci2+1/Cin , etc.)
Les mer.
