Kan dere gi en forklaring på hva som menes med flg utsnitt fra IEC 60079-14, 16.2.2.5.3: spesielt pkt b er ikke enkelt å fortolke.
16.2.2.5.3 Unused cores in cables
Each unused core in a cable shall either:
a) be adequately insulated from earth and from each other at both ends by the use of suitable terminations, orb) if other circuits in the cable have an earth connection (e.g. via the associated apparatus), be connected to the earth point used to earth any intrinsically safe circuits in the same cable, but shall be adequately insulated from earth and from each other by the use of suitable terminations at the other end.
Les mer.
