Hi! I wonder if anyone has an explanation to when use 8.8 and when use A4?
As for busbars and cabinet indoor I am used to use 8.8. But does anyone knows why? Is there much difference in resistance for the A4 to 8.8? As long as correct tourq is used . Cost more with A4. Is there any disvantage using 8.8 A4 ?
If there was a cabinet outdoor with cobber bars and fuses / to fasten the cable lugs do you still use 8.8 or is it better using A4? For earth bars i see many times they use A4 bolts at the rig /offshore.
Les mer.
