Application of NORSOK Z-015
Spurt ${formatDate(1471342363)} av Nathan Darnell | Siste svar ${formatDate(latestComment().postDate.timestamp)} av ${latestComment().author.name}
Nathan Darnell
Hi, Could someone please clarify which equipment NORSOK Z-015 is intended to be applied to?
Is it only applicable to equipment, which is in a container/frame or on a skid? such as HPU's, compressors and workshops, OR does it apply to all equipment, including 'loose equipment', which is not in a container/frame or on a skid? such as bandsaws and drilling units.
Does it apply to equipment that is directly hooked up to the installation? OR to all equipment that requires hook up regardless of where it is in a system?
